Home > Technical (L322) > What is this part?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
What is this part?
Hi Everyone,
I needed to replace my passenger side valve cover gasket (I'm in the USA with a LHD car) and while disconnecting the battery I saw a mouse had chewed a hole through what looks like either a vent or a cover for a wiring loom. But, I haven't been able to find the part name/number.
I put a red circle around the hole in the attached picture.
Depending on the price and difficulty to replace I may just patch it with some RTV.
Any idea or pointers?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #647515 6th Nov 2022 6:15pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Damned rodents Censored
I'd patch it right up with a dab of black RTV sealant. You can reasonably smoothen the material with wet fingers to a near perfect finish. Replacing could do more harm than good.
Post #647519 6th Nov 2022 6:40pm
lschwarcz
Yep, I'll almost certainly end up doing the RTV patch. But, I'd still like to know what it is. If it's not too expensive and not too difficult to replace I may replace it.
I guess I'm just a bit too pedantic Smile.
Thanks!
Bournville/Ivory
Post #647520 6th Nov 2022 6:44pm
lschwarcz
Could this be the part? It's hard to tell from the parts images.
https://partssaclandrover.niello.com/oem-p...-ypo000370
Thanks!
Bournville/Ivory
Post #647681 8th Nov 2022 5:41pm
Phoenix
It looks very much like the bulkhead grommet for the electrical harness.
Changing that (if available, which I very much doubt) would be a very involved job. RTV won't bond successfully to it, better to use a tyre patch and some tyre patch adhesive, once fitted, give the edges an overcoat of tyre adhesive. Make sure you clean the grommet and the tyre patch well beforehand with some tyre buffer or adhesion promoter, scuffing the area where the patch will go with remove any oxidisation and provide a 'key'. You can use a mushroom patch, just cut off the stem.
Post #647691 8th Nov 2022 6:56pm
The front left corner of your picture is another wiring loom the mice seem to love! Had several cars in with spurious faults due to rodent damage!!!
Post #647779 9th Nov 2022 6:50pm
lschwarcz
RTV won't adhere? Never even considered the possibility. I'll swing by my local car parts store to buy some of the tire patch you suggested.
Thanks,
Bournville/Ivory
Post #647927 11th Nov 2022 11:24pm
lschwarcz
The black plastic one or the brown ground wire? The ground wire has already been chewed up a bit too. I'm going to replace that since it's an easy replacement.
Thanks,
Bournville/Ivory
Post #647928 11th Nov 2022 11:25pm
The Black plastic one… if you have the time? I did a small write up on just this issue and put some pictures up where some customers cars were chewed and what the wiring was for (if I remember correctly?) 👍
Post #647946 12th Nov 2022 11:46am
