![]() | Home > Technical (L322) > Intake manifold cleaning |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1000 ![]() ![]() ![]() |
I hope that does the job, 4 x cans in the UK is over £100
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Here the same, over 100€. But its much much cheaper than remove the manifold, and even then anywhy can`t clean the channels near valves in the head (only by walnut shell blasting).
Yes, "Restricted performance" showing immidietly when add the rpm-s to 2000. But I have iCarsoft, so erase this error easy after work is done. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
What actual benefits are there to having a clean intake ? 2012 TDV8 Vogue (L322) |
The result.
Where the intake narrows the intake velocity will be higher so deposits will be thinner. It's a diesel engine - it's never going to be clean. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
I'm working on the theory that with my EGR now non-operational that the inlet manifolds will eventually be cleaned by the air now being free of exhaust carbon, but I won't be removing the plenum to check. I will however keep a check on the MAP sensor which should now stay clean. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
Can't say I would spray one can in mine, any cleaner must be solvent based, you have sprayed a powerful solvent straight into the engine, this will wash the bores of diesel and remove lubrication in the upper part of the engine, it could also dilute the oil.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
FWIW I had mine Terra Cleaned. I’ve not inspected it since but it does seem more responsive and the mpg has gone up by about 1 mpg ! ( which is 3% ). TDV8 4.4 2012 |
JayGee:
Given how quickly the MAP sensor soots up it would seem pointless even if you could clean it...... 2012 TDV8 Vogue (L322) |
Here you are right JayGee, I have driven 1000km after plenum chamber cleaning and MAP was also cleaned of course, and in this short distance MAP was littlebit clogged already.
Most people are just driving and clocking up huge mileages with no loss of power or MPG. Just clean the MAP every service and stop worrying about it |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
I’ve used Liqui Moly injector cleaner on my P38 2.5d last year and that worked well.
