Home > Technical (L322) > MOT Time
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
MOT Time
Well the old girl (2012) went in for MOT and passed with x2 advisories both relating to grease on brake lines (Which i put on to stop them rotting) and that was it.
Very happy Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #647833 10th Nov 2022 5:03pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
What were the advisories, and what mileage has the old girl done ?
Post #647979 13th Nov 2022 7:05am
garyRR
I got advisories for 'chips in windscreen' and 'suspension component rust'. When challenged, the guy showed me a minute windscreen chip not in the driver's field of view. And they said the suspension component was surface rust on the chassis, so to just wire brush it off. The guy remarked "you'd struggle not to find a chassis with surface rust on vehicles older than about 5 years".
When I booked the windscreen company, they struggled to see the chip and then couldn't repair it anyway, because it was far too small. They said it shouldn't have been an advisory.
Re the chassis, no action taken. It's pretty clean from my perspective, and I still wonder today why if most vehicles on the road are are in the same position, why it's even an advisory. 2015 Range Rover Autobiography 4.4 SDV8
Post #647980 13th Nov 2022 10:11am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I do sometimes wonder If they just add something for their justification?.
Yet I've seen vehicles that have passed an MOT, Having been porly repaired from accident damage & should Not be on the road, because it doesn't fall within the inspection criteria.
Post #647982 13th Nov 2022 10:47am
JayGee
I was impressed by how mine passed with minimum issues. I’d be more impressed if like some other counties we had dedicated gov run testing stations and not garages with licences to test. 2012 TDV8 Vogue (L322)
Post #647984 13th Nov 2022 11:44am
garyRR
I think many hundreds of thousands of instances where the garage are friendly with the owners of the car would end up failing! 2015 Range Rover Autobiography 4.4 SDV8
Post #647985 13th Nov 2022 11:47am
JayGee
I bought mine with 11 months MOT and it was literally unbelievable it had passed. Likely due to a ‘friendly’ MOT tester…… 2012 TDV8 Vogue (L322)
Post #647987 13th Nov 2022 12:16pm
Phoenix
An 'advisory' is something the tester has noticed that is not a minor defect but may become one (or a major defect).
Windscreen chips are 'advised' or to use the certificate wording, 'monitor and repair if necessary', same goes for tyre tread depth.
The information is there to assist the driver/owner in keeping their vehicle safe & legal to be on the road in the future.
I realise there's an amount of pride in having a 'clean' MoT certificate, but given it's legal status, advisories have to be made where checked items have the possibility to become minor or major defects in the future - so there is no 'I didn't know about it' defence.
I'm (thankfully) not a MoT tester but I do work with several, what really grips their $h!t is when vehicles are presented with defects that most people know will lead to a failure - vanity plates, SRS, ABS, EML illuminated, brake wear warning, TPMS faults etc. etc. and then p!ss & moan if they're advised it will fail or has failed.
Post #647989 13th Nov 2022 2:16pm
landy95
United Kingdom 2011 Range Rover Autobiography TDV8 Sumatra Black
I forgot to remove my dash cam and got an advisory for it, he removed it and passed the mot, thats a bit OTT if you ask me. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #648007 13th Nov 2022 10:18pm
garyRR
Probably because it was obscuring the field of view?
Tuck it behind the rear view mirror, out of sight? 2015 Range Rover Autobiography 4.4 SDV8
Post #648009 13th Nov 2022 10:22pm
Phoenix
Depends where on the screen it was, if within the area swept by the wipers - and therefore considered to be in the drivers field of view, an 'advisory' to let you know it's potentially obstructing your view of the road would be correctly given.
Post #648011 13th Nov 2022 10:24pm
JayGee
That's 'Jobsworth of the year award' territory....... 2012 TDV8 Vogue (L322)
Post #648032 14th Nov 2022 9:13am
dingg1
Its what vosa likes to see though, they don't want to see a test station just passing through lots of vehicles with pass certs without advisories and want to see a proportionate number of failures too.
Hence my mate putting an advisory on mine one time for a 'smelly' hanging from the rear view mirror Laughing
Post #648034 14th Nov 2022 10:46am
Jayk69
just the 2 grease on brake lines.
she has done 135k 2012 Vogue 4.4 TDV8 - Current
Post #648039 14th Nov 2022 11:16am
