![]() | Home > Technical (L322) > Electrical issues /Parking sensors problem |
| longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95
I am assuming there’s an issue with the driver side outter parking sensor… (mostly likely the wiring going to the sensor got pulled )
| G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98
I bought my car with the parking sensors not working - front and rear. Turned out to be the rear bumper wiring loom. Was only £40 for a new loom from ducksworth |
Thanks for that info!
Double post |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3397
Likley just a cut wire where they go through the inner steel bumper (Common result after a nudge) so can be repaired without doing the whole loom. 2012 TDV8 Vogue (L322) |
Thanks guys will pull the bumper off and check for continuity on the loom , pia. Lol |
Pulled the bumper off and tested loom am getting continuity across all there sensor wires !
So I had a bit of time this evening and decided to remove the sheathing and tape on the loom … as you said broken wire !!! Obviously when I tested the wire it was bloody working !!! Lol |
Looks like this has happened before
The wiring on these cars is terrible quality. Bare unsheathed ends to connectors exposed to the elements and vulnerable to minor abrasions and impacts. They were never designed to last long..... 2012 TDV8 Vogue (L322) |
