Home > Technical (L322) > Testing viscous fan |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 332 |
Anyone able to just check there’s for me please 2012 Range Rover Westminster 4.4 TDV8
14th Nov 2022 8:33pm |
anyone 2012 Range Rover Westminster 4.4 TDV8
17th Nov 2022 1:08pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2727 |
I'll test the fan cold when I get back from work later this afternoon 2012 TDV8 Vogue (L322) |
17th Nov 2022 2:35pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
will check over the weekend i can check cold but have to wait to check hot as i need to replce top hose.
17th Nov 2022 3:40pm |
Doesn't spin free when cold on mine. Definitely feels like it's connected to something with 'drag' 2012 TDV8 Vogue (L322) |
17th Nov 2022 7:07pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
You are aware that the engine cooling fan is electrically controlled with a variable lockup clutch controlled by a PWM signal, aren't you? the checks above won't really tell you much about the correct operation of it. ETA: From Topix
17th Nov 2022 7:30pm |
The fact that it makes a loud clicking sound would be enough for me know something is very wrong without any other tests. 2012 TDV8 Vogue (L322) |
17th Nov 2022 7:41pm |
i get a ticking sound when i start cold as i understand things this is the VF i always thought it was the Heater thingy trying to fire up. anyhow the clicking stops as the car warms up. 2012 Vogue 4.4 TDV8 - Current
18th Nov 2022 12:59pm |
Mine has drag when cold and hot 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
18th Nov 2022 1:19pm |
2012 tdv8 doesn't have a separate fan for the AC it got a electric clutch in it for the AC 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
18th Nov 2022 1:21pm |
Mine doesn't tick. It doesn't 'rev up' when started but does when moving off hot or cold. 2012 TDV8 Vogue (L322) |
18th Nov 2022 2:33pm |
I stand corrected i could have sworn i had a fan on front of the rad pack but alas no it does not, My TD6 defiantly did. appologies for the duff info 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
18th Nov 2022 2:36pm |
No worries mate i appreciate you taking the time to try to help 2012 Range Rover Westminster 4.4 TDV8
19th Nov 2022 9:09am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Mine isn't a TDV8 but a 4.2 Supercharged. I also had a problem where the viscous fan made a loud metalic clicking noise when cold, it worked otherwise and cooled the car properly. I bought a new viscous fan as the noise became annoying. |
19th Nov 2022 3:11pm |
