![]() | Home > Maintenance & Mods (L405) > LED Lightbar Install |
| Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369
That’s a very neat installation. Looks like a perfect solution to the poor output of the pre-2018 lights without spoiling the looks. 2019 L405 SDV8 Autobiography
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Very similar to my install… I’m working on a can-bus relay solution atm to allow it to only come on at a pre programmed speed! So say above 40 or 50mph so your not dazzling other drivers unnecessarily at slow speeds… 👍 |
| SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110
Hi Craig,
I’ll be able to get it I’m sure sir… Not my department, but yes it will have to be decoded if not done already? |
Hi, that would be fab, something I have been after for years! 2019 L405 SV Autobiography |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
That looks a great fit in that space. Do you feel the grill affects the light pattern as is you see darker parts cause its blocked, or is it all quite even? V8 or else ... |
| Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 115
Light distribution is quite even. No grille pattern is projected as far as I can tell.
