![]() | Home > Maintenance & Mods (L322) > Bouncy ride |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
over the past few weeks, I have had the feeling the ride was becoming a little bouncy, more evident at slower speeds, on smooth faster roads it's not really noticeable. My thoughts are it's shock absorber related, the front struts were replaced by the dealers only a couple of years back so more likely the rears as they are likely original. The question is how do I test them?
The first round of checks would be:~
I presume the front struts were changed due to air spring failure like most, but that was before my ownership. I am not about to throw money at guesses, here in Australia RR parts are stupidly expensive so I would rather spend some time identifying the problem. How does one test a shock absorber on an air-sprung car, I can only think to remove them and test resistance.
It's exactly that, but check recovery time too - if it recovers too fast, then it's worn. Dampers are the same construction for both coil & air-sprung vehicles. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2705 ![]() ![]() |
Hand testing of a shock can at best reveal that it is totally worn-out. A shock test machine is required to properly test how well a shock performs but a discerning driver can do a pretty good job too, especially if the vehicle is loaded and tested on poor roads. |
Along with a bouncy ride it will feel very unstable when cornering on worn shocks - often alarmingly so. The rears are cheap and easy to replace. 2012 TDV8 Vogue (L322) |
I think the only people with a damper test set are the damper manufacturers, I've never seen one in any dealership and the tests listed in work instructions at best only give compression force values and recovery rate times. Things may be different for you though. |
Hand testing off the car won’t tell you much as you need to be able to compress and extend the shock with a lot of force and speed to replicate the action on a car which is way more than you can with your hand. I’ve seen MOT testers check cars by lowering the lift and stopping it to see how the car bounces as it uses the weight of the car. The old test of bouncing each corner by pushing down with your body weight is ineffective on such a heavy car supported by stiff springs. 2012 TDV8 Vogue (L322) |
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
An easy way to check the shocks (not the air bags) is to drive alongside it in another car and look at the wheels. If the shock is done the wheel will be bouncing up and down almost all the time. |
After checking everything I could and with the help of a spotter the conclusion was A tyre was out of true. Finally got a new set of tyres fitted today and the ride is restored. I fitted Bridgestone Alenza 275 55 20`s having removed the strut pips and flattened the bulge in the osr arch liner. Happy to report no rubbing. 2007 TDV8 VSE
