![]() | Home > Technical (L405) > Driver door won’t latch |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
It may be frozen inside. My earlier L322 used to do this. Warmed it up and it worked. Try silicon spray instead of WD40. |
Spray some de-icer in there? |
| cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 72
I had this last week. Door latch needed replacing. I've had it done on 3 doors now. A common fault. They also get stuck shut. |
| kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289
Many thanks for replies. Called AA (local garage attended), mechanic gave side of door mechanism three taps with his screw driver/hammer and it freed itself (something to do with a spring). He then drowned the mechanism in lubricant. All fine now but he says it will have to be replaced and job will have to be done by dealer as it has to be programmed.
I got mine done by the dealer under warranty so unsure of cost. Its a common issue for the door latches to go. Mine was intermittent, if you slammed the door hard sometimes it would reset for a while. |
We do them all the time! Just as common as on the 322 beforehand! NO they 100% do NOT need coding/programming sir… |
Thanks Craig, can you give me a rough guide as to replacement price please? Many thanks |
Can anybody give me the part number for a replacement driver’s door lock please? |
send Duckworths your vin |
Thanks Craig |
| All times are GMT |
