Home > In Car Electronics (L405) > 360 Degree camera blurry?
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi All,
I have a 2019 SV with 360 cameras. When viewing the image as 360, the front camera area is all blurry, and cannot really see anything, just squashed up. The image is perfect when I select to view only the front camera. Has anyone else had this?
Post #647884 11th Nov 2022 12:26pm
No...but obviously earlier tech on the 2017. Mike - MPx
Post #647931 12th Nov 2022 12:34am
SVAuto_Man
Hi all, this is the issue I am having. As you can see the forward camera image is clear but the 360 view of it is blurred.
 2019 L405 SV Autobiography
Post #648625 20th Nov 2022 2:52pm
mgibson
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Jet washing
Just been to dealer as rear camera failed on my 2018 L405 with 360 cameras , they rejected claim under Land Rover warranty as water ingress caused the fault . As a courtesy they washed the cars so now three cameras not working and fogged up . Surely dealers should tell valeters to keep jet washers away from door handles and cameras . Hope that they dry out and I can seal the lenses with Vaseline when they start working again . Dealer is looking at replacing the failed rear camera though so fair . Don’t jet washers any Landrover !
Post #720411 26th Jun 2025 4:34pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
it's not blurry. It is not calibrated, and at top view you have whole wide view from camera.
There is software bug - you need to update module firmware in IPMB
Post #720421 26th Jun 2025 8:41pm
