Home > Maintenance & Mods (L405) > l405 battery
Page 1 of 8 12345678>
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
l405 battery
hi, Guys, I`m looking to get a replacement battery for my 2017 sdv8 has anyone bought one? if so what did you buy and from where?
Thanks for any advise
Post #648409 18th Nov 2022 10:22am
Fifth Horseman
When I replaced the main battery (under the spare wheel) I used a Yuasa YBX9019 from tanya.co.uk
A replacement for the secondary battery (behind the RH boot side panel) I believe would be YBX9096
The battery management system will need to be reset following main battery replacement.
Post #648561 19th Nov 2022 6:56pm
Tinman
Post #648590 20th Nov 2022 8:56am
Have you checked what a new one would cost through the site sponsors?
Post #648608 20th Nov 2022 11:48am
Tinman
Not yet CTC I have had two quotes one for £190 Duracell, and another for £162 Bowerbatt
Post #648623 20th Nov 2022 2:49pm
Kot
So my 2018 SDV8 has the original battery so far so good Thumbs Up
But with Tinman having to replace his battery on a 2017 guess I have at least another year to run.
I tend to charge every 3 to 4 months with my Ctek but thats when I get the "Start the car" message, gradual drain is my dash cam and short journeys takes its toll.
My question is--
What's the average amount of years before they start to decay. ( I try every trip to hit the disable auto start button) Rolling with laughter
So what's the record for battery longevity ? Whistle 2018 SE SDV8 4.4 Byron Blue
Post #648671 20th Nov 2022 7:40pm
Tinman
The reason that I think that I need a battery is I have a battery monitor connected which shows that the cranking is below what it should be for starting, I became aware of a problem when as the previous post said that after leaving the tailgate open for a short while the bong came on the dash to start the car.
The monitor shows the charging condition and the battery, which I found helpful as the colder weather is coming and we know what a bad battery does for a full-fat RR.
Post #648691 20th Nov 2022 11:22pm
cass
Might seem wasteful but I treat batteries as a service item and change them as soon as I get a “new” car, especially a big engined automatic.
Under £150 delivered for a branded AGM battery from Tayna every 3 years just seems like a drop in the ocean of RR running costs and provides cheap peace of mind as we all know how huffy our cars can get if they feel deprived of volts.
Post #648697 21st Nov 2022 1:55am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So in the last month, I got the low battery warning twice. I am charging the battery now. The battery is 3 years old only, but for most of the first year, it was in a showroom. Should I think about replacing it?
Has anyone got a battery sensor on the main battery? Do they return valuable data? I know I have the Ctek connector under the bonnet with the LED marks, but it always shows a middle-charged battery. I remember reading that I would get different results connecting directly to the main battery. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #649103 25th Nov 2022 3:47pm
caymanblack
Does this mean it has to go to the Dealers Fifth?
Post #649112 25th Nov 2022 4:48pm
if you have one, then the GAP iidtool can reset the battery.. ... - .- -.
Post #649114 25th Nov 2022 5:01pm
luxmoggy
So I have my multi-meter connected to the terminals under the bonnet. This is after some longer drives today on the motorway.
@17:12 12.52v
@17:33 12.47v
@17:51 12.18v
@19:02 12.21v
After watching "Raymies Garage" YouTube video about battery replacement and his battery monitor. I think that my battery is on the way out. I am driving to Italy in the mountains and don't want to get stuck.
Am I correct in my thinking? SDV8 AB MY 2020
Post #649233 26th Nov 2022 7:18pm
Gremlin500
……….. V6 Vogue - “Less is More” - less to go wrong!
Post #649234 26th Nov 2022 7:26pm
luxmoggy
This is also after being on the CTek charger overnight. So I think it is very much coming to the end of its life.
As my car is 2020 version, to tell the system I have new batteries, is it a trip to the main dealers? SDV8 AB MY 2020
Post #649235 26th Nov 2022 7:30pm
Gremlin500
………… V6 Vogue - “Less is More” - less to go wrong!
Post #649241 26th Nov 2022 7:58pm
