Home > Technical (L322) > One Windscreen Wiper Stuck Vertical
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Afternoon all,
Wife just went out in the fattie and about 5 mins later was back to change cars.
The ofs wiper is stuck in the vertical position and the near side is parked. I haven’t had a good look under there yet as it is p33ing down Laughing
Anyone has this or got any idea which bit of the mechanism I need to target please?
Thanks
Post #648738 21st Nov 2022 2:27pm
Goldstar
Decided I needed to get out there despite the rain.
Here’s the culprit. Arm had jammed behind the n/s spindle
Trouble is now I’m not sure the cup on the arm and the wiper are very secure now. Just in time for winter.
Post #648741 21st Nov 2022 2:49pm
Phoenix
As a temporary fix, put some polythene sheet over the ball then press into the socket with a decent pair of pliers, you'll need to replace the linkage assembly soon though.
Post #648742 21st Nov 2022 3:02pm
JayGee
Happened to me this summer while on holiday and managed to bodge it but it's secure so won't come off but loose and the wiper hits the A pillar so just ordered this kit;
https://www.ebay.co.uk/itm/143538883971?mk...media=COPY 2012 TDV8 Vogue (L322)
Post #648744 21st Nov 2022 3:12pm
Goldstar
Looks like it would work. Worth a go at £25, thank for the link
Post #648772 21st Nov 2022 7:14pm
Goldstar
I'll give that a try thanks
Post #648774 21st Nov 2022 7:21pm
Stuart-
This happened to my L322 a couple of years ago. The ball and socket wears and eventually pops out. The indy gave me a retaining clip that holds both together.
>>This<< looks like the sort of thing. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1991 Mercedes 420 SEL
Post #648777 21st Nov 2022 7:36pm
Goldstar
Added some polythene and the ball clicked into the socket with a satisfying thunk but I suspect it won't last long. Ordered some of those clips (thanks Stuart) to see if they will work
Thanks all
Post #648911 22nd Nov 2022 9:40pm
