![]() | Home > Technical (L322) > Isofix nightmare. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
Is the seat new?
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 466 ![]() ![]() ![]() |
One base is new one is a bit used, but it’s a seat problem as you said. So did you run it with just one arm fixed in? I guess you mean the movement of the seat opens the hole up a bit then it eventually clicks in? 2009 pre-facelift 3.6 TDV8. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
We’re just about to start using our L322 for the same thing.
We only ever use it when both anchors engage-but it took a lot of wiggles and expletives.
I did see them but not sure they would fit in the gap themselves, trying my best not to ruin the leather too. Has anyone else used these guides successfully?
Let’s just say I tried to ‘ram it in!’, going to poke a screwdriver around the back of the fixing point and see if I can clear the way a little. My back seats look like they have never been sat in, never mind having a kids seat in there! It seems to half latch but not fully grab the isofix bar, this probably adds to the reason the arm doesn’t stay extended. Did you have the issue on the same point? Rear passenger left hook? 2009 pre-facelift 3.6 TDV8. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 669 ![]() ![]() ![]() |
We had a isofix in our L322 for a few months before we sold it, we had a couple of old glasses cleaning cloths to protect the leather and enable the rails to slide back easily as well as a maxi cosi seat protector but other than that the Maxi Cosi seats just slid straight in likewise on the L405 we have today. Both had unmarked isofix rails prior so had never been used.
Thanks. Been using isofix in my wife’s 2009 Honda Civic for the past two months with no issues and yep - arms are fully extended. I have a thin-ish seat protector and from what I can see the leather seems fine so far (the seat protector is not getting in the way, I checked!). The thing just won’t click in so guessing something is happening to stop it biting on the bar. The side closer to the door that has clicked in already has a little more room around it. Let’s see how I get on tomorrow, it really shouldn’t be this hard! 2009 pre-facelift 3.6 TDV8. |
Just a thought, but could you hold the rails to stop them retracting until it’s latched properly? It kinda sounds like it’s going in too high or low and that the arms are hitting the rails above or below and just retracting them rather than latching?
Yes tried holding the rails while pushing the base, no luck. It literally lines up by what I can see by eye, something is clearly impeding it perhaps from the back side. Crap picture but…
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
We have a Cybex Z-base on our L322 and it was a quite tight fit, hooks seem to be somewhat low so that it´s not just plug and play as it is for example on our Saab 9-3. You really need to push the seat cushion down from the back end to get those base anchors to line up with hooks.
Yes we have two Cybex Z-bases. If this thing ever goes in I am not taking it out, that’s for sure. The odd thing for me is I can see them lining up, just not clicking in. I will put more pressure on the seat when I try again tomorrow, maybe it likes quite a flat angle to join. Just annoying as although fiddly the other arm went in as expected at the same approach angle as the one with the issue. 2009 pre-facelift 3.6 TDV8. |
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 ![]() ![]() ![]() |
I agree, the L322 is by far the worst car I had from an isofix-friendliness perspective.
So you got it as close as possible and tapped the plastic bit on the arm? 2009 pre-facelift 3.6 TDV8. |
