![]() | Home > Off Topic > pulling out a tree stump |
Diesel Powa!
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Its out the front and to get the angle so the rope doesn't take my front wall out ill be half on the pavement, half in the road. My only concern is the front wall, its only 2 feet away so may have roots underneath, but pulling it out with the rangy will make a real B of a job fun.... |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Make sure you get someone to video it, so we can all enjoy the fun. |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Yeah video. If anything does go wrong at least you can get £250 for it. |
Yup, done a few of these with various Landys. Best advice is to spend half an hour digging round it and then use a bowsaw to cut through any thick roots before you drag it out.
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I've done quite a few in my time...
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Get a grub axe. Ideal if you also fancy amputating your legs in the process !
Thanks for advice..
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 ![]() ![]() ![]() |
A longer rope and "rock" back and forwards rather than just trying to rip it out in one go. Dig around the stump, it's surpising how far the roots go. Cut the ones that go off in the direction of the wall.
Also make sure that during the pull there are no people anywhere within the radius of the rope. Breaking ropes can cause nasty injuries and even kill. Also try to find a rope with not too much stretch in it and if you can a chain around the stump. Chain digs into the stump to get a better hold. Don't use shock loads, the RR should be more than powerful enough. Shock loads can damage the car and rope while a steady load is less likely to do that.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
I haven't read all the replys but I would use a recovery strap - rated to 5 tons at least, and wrapped round the trunk a few times - they are cheap on ebay. I bought a 10 metre one, you can always double it over for towing on the road - cost was around £9 delivered.
When using a long rope, wire or synthetic, you should put a heavy blanket or something like that in the center of the rope, this will reduce the possibilities of the hook reaching the tow vehicle.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
If you have a problem I can pop past with my Camel Defender, complete with winch and assorted gear.
