Home > Technical (L405) > Strange smell & slight smoke
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys been getting a strange smell when stationary with window open I can smell it from drivers side only and same when out vehicle just around drivers side similar to a sticking brake pad sort of smell upon opening the bonnet after a long drive there was obvious slight wisp of smoke in engine bay nothing major but I could make out the smell again. It can’t be brake pad related as no smoke or excessive heat round that area. Thoughts anybody?
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #649078 25th Nov 2022 10:46am
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Did it smell almost like metal? if so, could be a re-gen 2019 L405 SV Autobiography
Post #649079 25th Nov 2022 10:54am
jaysta10k
Hi Martin would a bad re gen cause a slight wisp of smoke also? How would you cure this also a bad re gen
Cheers
Previous Cars
BMW M3 Carbon Black
Post #649083 25th Nov 2022 11:12am
SVAuto_Man
Hi ya, not a bad regen, just a normal regen. The exhaust system gets VERY hot during a re-gen so any debris, dirt, etc. that's on it could smoke etc. Drive the car again, let it get hot with over 1/4 tank of fuel. if it does it again, check if your MPG has dropped through the floor. if it has, its a re-gen. If it is, get on a motorway if you can, put it in manual mode, and drive it for about 20 mins over 2000rpm. That will clear it. 2019 L405 SV Autobiography
Post #649084 25th Nov 2022 11:17am
DrRob
Oil cooler leaking into the "V" perhaps? Common issue on the 4.4 V8 diesel.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #649085 25th Nov 2022 11:26am
jaysta10k
Don’t think it’s a re gen issue as MPG all good doing 90 miles a day round trip so car being used on long journeys etc..Just strange as it smells similar to break caliper sticking but they are fine breaks recently changed all round so all good. Smell is only really noticeable outside car by drivers side. And also when sat in traffic with window open can smell again from drivers side. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #649087 25th Nov 2022 11:38am
Just a thought, your FBH is front drivers side, that hasn't been on when it shouldn't be has it..?? Pete
-Click here for Thread-
Post #649130 25th Nov 2022 6:42pm
SVAuto_Man
Good shout!!!! It comes on to warm 4.4 up 2019 L405 SV Autobiography
Post #649135 25th Nov 2022 6:50pm
jaysta10k
Thought the FBH only came on when the remote is pressed or set within the cabin on a timer to come on. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #649156 25th Nov 2022 9:50pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
FBH will come on automatically if ambient temp is below cerca 10C to assist engine / cabin temp to warm up.
Post #649163 25th Nov 2022 10:50pm
GraemeS
Australia
My bet is the aforementioned leaking oil cooler, either the gaskets or the o-rings for the oil pipe or both, causing oil to drip onto the cross-over pipe primarily on the right side.
Post #649169 26th Nov 2022 12:08am
jaysta10k
How long does the FBH stay on for this to assist with warming up cabin. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #649289 27th Nov 2022 4:51pm
jaysta10k
cheers for this I will look into this also as the smell is starting to @@@@ me off now! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #649290 27th Nov 2022 4:52pm
DrRob
Look underneath at rear of engine area for leaks.
On an L322, you whip off the pollen box, engine cover and then get a torch and look down into V and rear of V. Helps if you put bonnet in service mode. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #649302 27th Nov 2022 7:31pm
diesel Dave
TBH I can’t remember the exact numbers but it stays on till the engine is almost to running temperature if the ambient temperature is low. It is all in the workshop manual which gives all the parameters it kicks in and out at, some good bedtime reading. Very Happy
Post #649370 28th Nov 2022 5:51pm
