![]() | Home > Technical (L322) > cutting out |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3304 ![]() ![]() ![]() |
Did this happen before you replaced the battery? 2012 TDV8 Vogue (L322) |
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 53 ![]() ![]() |
Hi, before. The battery was checked and deemed at fault, hence changing it. 2008 TDv8 Vogue in Java black x2
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Engine / body earth wires clean connections and sound wires? BMW i3 Electric Car
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Make sure the battery leads are right down on the posts. I have had to tap them down before as they are slightly conical in shape. John
If the concern was evident before changing the battery, then it's not the battery causing it.
Not had them read yet, i've not got a reader for this one. decided to leave it to the garage for now. 2008 TDv8 Vogue in Java black x2
Where are you in Sussex? I have a Gap iiD if you are near me and would like the faults read. John
Hi near worthing. Thanks, but dropped off at the garage now. 2008 TDv8 Vogue in Java black x2
Well, Garage rang, no further forward, non of there scanners can read the live data they wanted. I still think it's electrical, however they tell me it's fuel fault. Not sure, as many warnings up on the dash. all well 2008 TDv8 Vogue in Java black x2
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
Take up Weegies offer, can’t do any harm. Hunt for a L405 is on. |
was rather hopeing too.. 2008 TDv8 Vogue in Java black x2
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
How does it cut out?. Suddenly or gradually. Suddenly would indicate electrical, gradually would indicate fuel. See how you get on with Weegie |
Suddenly, no warning. 2008 TDv8 Vogue in Java black x2
