![]() | Home > Maintenance & Mods (L322) > My Hella Rallye 3003 LED setup. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
certainly look the business.. |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
Thanks for the |
I've found the light bars great for wide area illumination but not so great at range, the problem with snow is that there is a lot of reflection, so sometimes too much floodlighting can work against you as the glare prevents you seeing what the spotlights are picking up further ahead. Long range spots are great but need setting up carefully, I used Lightforce 240's with the HiD conversion kit, once you have the spot 'ranged in' , you can adjust the reflector to give you anything between full spot to full flood as conditions dictate. I used them for many years from Saharan Africa all the way up to Suomi Finland, The only reason I don't use them now is they were stolen (very carefully) from the front of my car, they managed to leave the HiD ballasts behind though.... |
https://i.imgur.com/FhN1ehR.mp4
I'm very impressed with those!
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 45 ![]() ![]() ![]() |
Here in Norway it's nice to be able to light up the road, but just as important also the terrain where there are lots of big animals like deer and moose lurking in the dark. Ready to jump on any incoming drivers.
As I still have another lightbar I'm thinking to put it above the other one and point the two Ralleys a bit more to the edges of the road, to, as ikjos said, be able to spot animals at the side ready to step onto the road.
