Home > Technical (L322) > Help me with the relay for cooling fan |
Eddy Member Since: 03 Mar 2022 Location: Italia Posts: 26 |
I specify that I bought it but I don't know where it is in the engine compartment |
28th Nov 2022 9:08am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
According to the wiring diagram the cooling fan is directly controlled by the ECM.
28th Nov 2022 10:04am |
Do you think the control unit acts directly on the viscous coupling without an intermediate relay? My problem arises only under load and off road: iidtool gives me error P 0480 - 13.
28th Nov 2022 11:07am |
Correct, there isn't a relay for the fan. It gets power from fuse 20 in the engine bay fuse box.
28th Nov 2022 11:30am |
Busarider Member Since: 17 Dec 2022 Location: Ontario Posts: 8 |
Hi, new the site and I’m having the same problem with the same code P0480-13. Was this issue fixed? Did you replace the viscous fan or was it electrical related? |
17th Dec 2022 7:59pm |
