![]() | Home > Technical (L322) > Urgent help required |
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 ![]() ![]() ![]() |
Hi Bembo
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2749 ![]() ![]() |
The TC will be bolted to the flex plate that is the equivalent to a flywheel but the TC stays with the gearbox when the gearbox is removed. Other vehicles have an access hole that allows 1 bolt to be removed then the TC rotated to access the next bolt so I assume the same on your vehicle. |
