![]() | Home > Technical (L322) > Brake feel |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3399
Describe 'wooden' as a break feel? 2012 TDV8 Vogue (L322) |
| Richo Member Since: 19 Nov 2022 Location: Lincolnshire Posts: 5
Not very sharpe really have to press pedal hard 😬😬 |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
They have 6 pot Brembos fitted so it should stop well.
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Without the engine running, press the pedal repeatedly until there's almost no movement, hold the pedal down and start the engine. Does the pedal move down (with normal foot pressure) almost immediately and sink to >50% of the total travel distance?
Will check just checked no engine running pumped pedal until full pedestrian started motor pedal goes down to about half way down 👍
It could be the surface of the discs is quite worn / uneven (or the edges heavily lipped) and not the full area of the pads is touching the surface of the brake disc. Typically, the inner working face is worse than the outer.
I find them very progressive - plenty of stopping power if you press hard and gentle speed control if treated gently. Just like the accelerator pedal but in reverse. Budget vs expensive pads should have the same friction coefficient as this is a legal requirement. Budget pads may wear differently, create more dust, make more noise or fade under hard prolonged braking but shouldn't really have much difference in overall feel. A change of brake fluid and a full bleed is worthwhile but you may have fun with the bleed screws in the front callipers as they are alloy and suffer from galvanic corrosion. 2012 TDV8 Vogue (L322) |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850
Bosch discs. Brembo pads. Is the combo i put on recently.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
It might be worth replacing all the discs and pads I always do with a new to me car and brake fluid and all other fluids you just dont know what has been done regardless of the history |
Replacing disks and pads all round is quite an expensive exercise esp if there may be nothing actual wrong …… 2012 TDV8 Vogue (L322) |
Yes I know but for me I like to know what quality of parts are on there I accept its not for everyone |
| All times are GMT |
