Home > Technical (L322) > New TC now stuck in nuetral
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
After replacing my TC with a new unit , went to do gearbox fill procedure but car crunches into park and says select nuetral on dash ! I haven't touched anything, only disassembled and rebuilt , ive placed the TB motor in the correct position but still getting the crunch into park wtf is going on ?? There were no faults before doing the work
Post #649996 6th Dec 2022 4:17pm
RRPhil
Have you tried a Fuse 37 reset, to calibrate the shift motor?
Phil
Post #649997 6th Dec 2022 4:47pm
bembo449
I was going to try this phil but i cant complete the process if i have no drive ??
Simon
Post #650004 6th Dec 2022 6:11pm
RRPhil
If the vehicle wonโ€™t drive forwards or backwards by the time you get to step 16 on the list then this isnโ€™t your issue.
Just to clarify, the vehicle in question is the one in your signature (2002 3.0l TD6)?
Are all of the driveshaft splines fully engaged? The driveline disconnection could be downstream of the transfer box. If that were the case, you would see one of the propshafts turning with the vehicle stationary in gear.
Phil
Post #650055 6th Dec 2022 11:43pm
bembo449
Ok phil ,will have another go at it today , i need to update my sig , have 2 06 td6 at the moment, oh and a disco 3 but thats another story
Post #650065 7th Dec 2022 9:23am
Richo
2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Transfer box in neutral gearbox output shaft still turning and parking pawl trying to engage into park brake wheel ๐Ÿ˜ฌ๐Ÿ˜ฌ
Post #650083 7th Dec 2022 1:28pm
bembo449
Reconnected everything today and i now have drive , so ive learned something, though i think my TB motor is jiggered , it goes into low but wont go back to hi range , just need to finish off refil procedure as i had an unexpected breakage on one of my other vehicles today , thanks to those who inputted
Simon
Post #650112 7th Dec 2022 6:03pm
Richo
Great good luck ๐Ÿ‘๐Ÿ‘
Post #650114 7th Dec 2022 6:19pm
bembo449
meant to update this , been back on the road a week or so , all good
thanks for the advice Thumbs Up
Post #651407 21st Dec 2022 8:53pm
