Home > Technical (L322) > Permanent fix for leaking throttle body pipe |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
I tried a single 3.125" ID x 5mm in the housing but it was too thick so will try a 3.125" x 1/8" next time. |
8th Dec 2022 10:15pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 332 |
Try the fix above it works 2000 miles later no leaks it’s a simple fix 2012 Range Rover Westminster 4.4 TDV8
9th Dec 2022 7:55am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Looks good!
9th Dec 2022 8:49am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Dec 2022 9:09am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2733 |
Mine isn’t leaking but will do this mod anyway - many thanks! 2012 TDV8 Vogue (L322) |
9th Dec 2022 9:38am |
Mine's not leaking but I'm looking for an appropriate replacement for the seal in the housing. Loose o-rings on the throttle body don't enthuse me. |
9th Dec 2022 9:46am |
GraemeS
9th Dec 2022 2:52pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Great work. I ended up replacing the hose, the throttle body, the donut hoses and the other pipe with the fragile plastic connector to resolve my intermittent restricted performance. However, when the seal starts to go on the throttle body connector, as it surely will, I’ll do this mod.
9th Dec 2022 5:07pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Just to add that I recommend the gas specification PTFE tape as a diagnostic step or temporary repair only (considering it costs 50p and you can get some in any hardware store), to confirm if the seal is causing a restricted performance problem or hold out until you can obtain a new part, not as a permanent repair.
9th Dec 2022 6:02pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 325 |
love the fix.
11th Aug 2023 2:12pm |
Did mine with 0 rings and PTFE as it was leaking a bit. Pretty sure it's made an improvement to drivability and the harsh 1-2 shift is now not noticable. Cant remember how many rings I used but it took considerable force to get the retaining ring to engage and it then became solidly fixed. 2012 TDV8 Vogue (L322) |
11th Aug 2023 5:33pm |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 |
Not leaking yet but Ordered the O Rings and will do this anyway 👍👍 2001, 4.4 TDV8, Vogue, Baltic Blue |
11th Aug 2023 5:41pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
Me also, ten 75mm x 3mm O rings for £5.50 on eBay, so I’ll have spares.
11th Aug 2023 8:12pm |
Just completed this and now have a movement free joint between the plastic intake and throttle body so assume it’ll be leak free, but I’ll check for any oily mess escaping after a few journeys.
21st Aug 2023 11:13am |
