![]() | Home > Technical (L322) > All discs feeling hot? |
How hot? Fronts hotter than rears or vice-versa? Heat is a product of braking so 'normal' up to a point, if the fronts are roughly equal temperature side-to-side and warmer than the rears, also roughly equal temperature side-to-side, then it sounds like normal behaviour.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3340 ![]() ![]() ![]() |
Disks should feel hot after a good drive. If the wheels feel hot as well you have a problem. 2012 TDV8 Vogue (L322) |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
All wheels are cold....front discs are cooler than the rears which are both so hot I can barely touch them - but both sides are about the same temperature so it could be normal? I am noticing some vibration coming from the front offside when I first pull away which feels like the brake sticking - which is making me think the issue is something effecting all of the brakes |
Jack each wheel and see if there is any binding 2012 TDV8 Vogue (L322) |
