![]() | Home > In Car Electronics (L405) > L405 Passenger Seat Randomly Moving |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
put the seat into your required position and memorise it on all the 3 memories...see what happens.. ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
It's probably a software fault, mine had the headrest on the passenger seat move down without any input from anyone a couple of times. The software was rebooted and no recurrence. I assume you don't have anything in the loadspace that could be pressing on the rear seat folding button, as operating the passenger side rear seat fold will move the front seat away (maybe optional on some models).
samb096 Member Since: 11 Dec 2022 Location: Scarborough Posts: 11 ![]() ![]() |
Thankyou for the reply. Can a software reboot be carried out by the owner or is this something that requires a trip to the garage? I have had the rear seats down but I think they’re all the way back up but I’ll check to see if they’re fully back upright, I wonder if the rear seat not quite been in its ‘home’ position is causing the front seat to not know where it is in its cycle? I did also wonder about changing the battery just as a precaution, on a 9 year old car it’s possible it’s still on it original battery and I’ve owned cars in the past where a failing battery plays havoc with the vehicle electronics. |
My software reboots were all done at the dealer, as also the battery tests. Maybe a more technical forum member can comment on DIY options. Software issues are not that uncommon with the L405 (at least going by mine). Maybe test the battery anyway too.
So the plot thickens, I’ve just been to the car now to put the owners manual away and as soon as I hit the unlock button on the key, the passenger seat started to move into its forward position again. Very odd. I wonder if there’s something in the unlock sequence that would cause the passenger seat to move? I could understand the drivers seat moving on unlocking the vehicle for easy access but I’m baffled as to why the passenger seat would move! |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410 ![]() ![]() |
Did you do this that Stan suggested? 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 2006 Bentley Flying Spur in silver |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1855 ![]() ![]() ![]() |
I may have sussed this for you:
That would make sense regarding ‘Passenger Seat Away’ I’m not sure how to find it in the menu but I’ll have a look when I get back home. Thanks for the link, I’ve had a look through the information on there, I’ve already found the switch on the top right hand side of the seat and that functions as it should to slide the seat forward and backwards. However the article states that it won’t function when the seatbelt is buckled and it’s happened twice now with a passenger in the car with the seat belt buckled so like you say if it is the ‘Passenger Seat Away’ then it can’t be functioning properly.
You would think that this would throw up some DTC’s, do you have access to a diagnostic tool? |
@samb096:
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
Mine has this, but it simply allows you to easily slide the front passenger seat forwards or backwards using the switch on the seat itself on the side, by the right shoulder. You can access it from driver or rear passenger. It doesn't do anything automatically, only when you press the switch. I guess it's not impossible that the switch could be 'stuck on' for the forward setting? (If you have this switch) FFRR SDV8 Autobiography |
My car had the little switch on the side of the seat however like I say, it’s moved forward by itself even with a passenger in the seat with the seatbelt on. I’ve tried to reprogram the seats memory all to the same position but because I’ve only got half the memory buttons illuminated I’m not sure if it’s not saving the settings are the orange memory light isn’t illuminating indicating the use to select either 1,2 or 3 for their settings. I’m wondering if it’s worth ordering another memory switch pack and seeing if that allows me to at least use the memory function? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
That was my initial thought. The switch on the side of the passenger seat at shoulder height. Intended for chauffeurs to be able to move the passenger seat forward / back without them having to move. I think it's only active when in Park, or something similar, which also seems to fit with the observed behaviour. |
@samb0, when you memorise the seat position a confirmation will be displayed on the instrument panel...make sure the ignition is on.. ... - .- -.
