![]() | Home > Technical (L405) > Dosing pump FBH SDV8 info required |
| recordman Member Since: 08 May 2013 Location: Kent Posts: 122
Have a look at this video, you might find it helpful:
| fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47
Yeah thanks for that, but i don't need to know how it works, i have three LR's with FBH, i have the above mentioned fault code for the dosing pump on a L405 2015 and wanted to know if anyone has replaced their one and if so where is it, how did they do it, any adaptives to be done etc etc... but thanks anyway.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
i've had a quick look through the WM but couldnt find any ref to the dosing pump...mind you it was a very quick look so i might have missed something... ... - .- -.
I suspect t will be hid up over the tank, if i follow the fuel line i will find it, you know how it is, spend two hours dismantling the car and its under a cover in the front wheel arch, thought i would ask before creating loads of work and breaking plastic clips off left right and center looking for something in a place for the L322 and LR actually thought about it and put it in a place more accessible on the L405 SDV8 2015 |
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Its in the WSM under
the word ''dosing'' threw me... |
Ah, well thats the fault code description, kinda thought best to stick with that than start using my own lingo... |
Ok great , many thanks... |
Just seen a write up in the WIKI its in the INFO . section near the bottom of the page but not sure which MY if its from a L405? 2018 SE SDV8 4.4 Byron Blue |
You are a super star, many thanks for pointing me in the right direction, loads of information that is greatly appreciated.. thanks again pat ☺️ SDV8 2015 |
| jstigers Member Since: 27 Feb 2023 Location: Norwalk CT Posts: 1
"Morning, I have a non operational FBH on my 2015 4.4SDV8 fault code read on iid tool is : B1D25-13 (C2) Dosing Pump circuit - General electrical failure - circuit open
Yes, simply unhook the rear passenger seat base on the UK driver side so 45 degree rear from your driver seat, pull the cut section of carpet out, pull the rubber grommet out and look inside forward, the pump is there, and the loose wiring harness is suspended close by, clean the terminals and use some electrical contact cleaner on both, push together to join, clear all fault codes, unless the ambient is below 6 degrees Celsius 43F the pump won't kick in, when the fbh runs it will smoke and smell for the first run or two after that you won't know it's running other than the engine coolant temperature will rise faster and the heater will get hot quicker. Hope that helps. Pat SDV8 2015 |
| All times are GMT |
