![]() | Home > Technical (L322) > TDV8 4.4 running temp? |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
Warmed up in about 20mins just now but still not getting above 75deg unless under load like uphill on the m-way. Needle on dash visibly dropping when slowing down on 50mph sections and hardly 70deg 2012 TDV8 Vogue (L322) |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Thermostat isn't closing properly, you can confirm with an IR thermometer or a FLIR if you can get your hands on one. |
I concur- the drop in temp simply should not be happening on a running engine. 2012 TDV8 Vogue (L322) |
| jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201
Also rubber seal on metal plate can be damaged on thermostat - then valve is not tight enough in closed position. - needs to replace whole thermostat insert. |
Running engines will normally drop in temperature, especially with a low ambient or high windchill factors, a working against load running engine should not. |
Had a quick chat with Ross at Glenrands and he immediately suspected the thermostat so booked in on Monday to have it changed. 2012 TDV8 Vogue (L322) |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Here you go JayGee:
also rubber seal on the edge of valve can be issue. is not tight enough. |
@GaryRR - those look similar temps to mine. 5 miles at 20mph ( London street limits) and 30mins and it's not up to what I'd call 'operating' temperature. 2012 TDV8 Vogue (L322) |
Seems a fair diagnosis then that your thermostat is stuck open until hot.
According to the workshop manual the thermostat should start to open at 88deg C. 2012 TDV8 Vogue (L322) |
Part supply problem at JLR means this job postponed. Hope it gets done before Xmas but not holding my breath. 2012 TDV8 Vogue (L322) |
Part still on backorder so definitely no fix until well into Jan now.. Started it up for the first time after being frozen solid for a week. FBH remote warmed up the inside nicely 10mins before I got in it which was nice. Let it idle while I cleared the snow and ICE and the temp gauge moved off cold fairly quickly but as soon as I'd driven 1/2 mile it had dropped back down again. Opened the bonnet and the radiator top hose and top of radiator were warm ( 25deg according to my infrared thermometer) but the engine parts were much colder so I'm in no doubt of the issue now. Looks like the weather is warming up next week so fingers crossed this is just a running issue and doesn't get worse. Thinking back it's been like this for ages but only obvious when the cold snap started. 2012 TDV8 Vogue (L322) |
Update.....
| All times are GMT |
