Home > Maintenance & Mods (L322) > GAP IID - What next?
Page 2 of 3 <123>
garyRR
Yes, my headlamp washers run every time when pressing the button in, but only every few times when pulling the stalk towards me. 2015 Range Rover Autobiography 4.4 SDV8
Post #650894 16th Dec 2022 12:23pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Headlamp washers are required bey law for HID headlamps, therefore there is no way to turn them off.
Post #650909 16th Dec 2022 2:45pm
DrRob
Interesting.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #650910 16th Dec 2022 2:51pm
DrRob
In UK?? I note you're in Switzerland Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650911 16th Dec 2022 2:51pm
dingg1
If headlight washers are fitted then they need to work for the uk mot.
Post #650912 16th Dec 2022 3:03pm
JayGee
HID headlights need working washer system for an MOT pass.
Also from the owners manual;
"If the headlamps are on, and there is sufficient
liquid in the washer reservoir, operating the
screen wash will also power-wash the
headlamps.
The headlamp power wash will operate on
every fifth operation of the screen washer,
provided the headlamps are still switched on
and approximately 10 minutes have elapsed
since the last headlamp wash.
Switching the headlamps or ignition off and
back on again, will reset the cycle.
Note: The headlamp washers are inhibited
when the washer fluid reservoir level is low."
 2012 TDV8 Vogue (L322)
Post #650913 16th Dec 2022 3:22pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Thanks, @garyRR
I reached out to GAP this afternoon and was quickly granted access to the full CCF file.
I now have 'unlock at ignition off' I'm very happy!
With full CCF access, are there any other functions we can utilise? I have DLRs etc already activated. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #650919 16th Dec 2022 4:53pm
TDV8_Tommy
Is it possible to configure the car to lower to access height at ignition-off?
Perhaps there is a reason, maintenance whilst working on/under the car. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #650923 16th Dec 2022 5:06pm
no you cant configure this on the L322....the auto access mode only came in on the L405 , around 2014/15 i think.. ... - .- -.
Post #650924 16th Dec 2022 5:15pm
johnboyairey wrote:
What the digital speedo upgrade in first post please.
Already in the WIKI.....
https://www.fullfatrr.com/forum/post645713.html#645713 Pete
-Click here for Thread-
Post #650929 16th Dec 2022 6:47pm
Tdtj
Well I asked for full ccf permission and got it. But for the life of me I can’t get it installed on my tool gggrrrrr
So asked again and gap said to download the latest update. Which I have done. So if anyone is Edinburgh or thereabouts can help would be much appreciated lol 2016 4.4 diesel
Post #650945 16th Dec 2022 10:49pm
you need to uninstall the gap updater, restart your computer and reinstall it ... ... - .- -.
Post #650958 17th Dec 2022 9:36am
Tdtj
Thanks Stan. Will give it a go later today 2016 4.4 diesel
Post #650959 17th Dec 2022 9:51am
garyRR
I wouldn't go about fiddling with other settings, because that's the entire catalogue for all vehicles and most parameters are not tested on the L322.
For access height at ignition off, you could put a little logic PCB in the driver's door, so on door unlock, it automatically emulates pressing the access mode button, also in the same door. 2015 Range Rover Autobiography 4.4 SDV8
Post #650981 17th Dec 2022 3:32pm
Tdtj
So I updated,or tried to update but it didn’t. So I emailed gap and they came back to say that there was an error on the database. So today updated with success and it opened up all the ccf and what an extensive list it is. At least now it unlocks at ignition off. Which is what I wanted 2016 4.4 diesel
Post #651279 20th Dec 2022 7:18pm
Page 2 of 3 <123>
