Home > Technical (L405) > L405 FBH verses D3 FBH.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
My previous Disco 3 had a FBH to help in the engine warm up time.
Does my current 2013 FFRR Vogue have a similar device.
The only one I can find is the one that pre warms the whole car.
Am I missing something ? 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #650939 16th Dec 2022 9:18pm
Phoenix
It's similar, the main difference is that the FFRR warms the car for the occupants only down to a pre-set ambient, then warms both the engine & cabin, below another pre-set ambient, it warms the engine only. I can't remember the temperatures, I'm sure they'll be on here somewhere.
Originally, the L319 was to have similar functionality (albeit with a different heater and control architecture) but the development overran due to quiescent current drain issues and the system was restricted to engine-only on startup below 5deg. C. There was an aftermarket modification to add a W-Bus controller to fire up the heater when the vehicle was shut down to pre-heat the coolant but not the cabin, later aftermarket iterations got warm air moving in the cabin but initially suffered similar battery issues as LR.
Post #650942 16th Dec 2022 9:45pm
GrandadRob
Many thanks Phoenix.
So does this happen automatically, or do I have an input. I don’t have a second remote. 2013 SDV8 4.4 SE Luxor.
Post #650943 16th Dec 2022 9:51pm
Phoenix
The remote may be an option - or just not supplied, there is a manual timer setting you can use.
ETA - this may help https://www.fullfatrr.com/forum/topic46437.html
Post #650946 16th Dec 2022 11:02pm
GrandadRob
Many thanks Thumbs Up 2013 SDV8 4.4 SE Luxor.
Post #650949 16th Dec 2022 11:22pm
