![]() | Home > Technical (L322) > Door won’t close! |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Don’t try ptfe lube- didn’t work!!! The only reason I don’t want to do the kettle trick is I’m worried that introducing more water into the mix might be causing a problem later on when it goes cold! 2009 (2010 MY) 5.0 Supercharged Autobiography
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 80 ![]() ![]() ![]() |
Dealer said they lubed it, power lockb which they replaced in April was fine. They said if it persists then they'll replace the cable next.
Well, door won't close again. Contacted the dealer who's going to quote the cable/assembly. Good times :/ 2012 Supercharged L322 |
Wife just had to clamber over and exit the driver door |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
Quite a good video that.
Indy pulled the cable and showed that wear and tear allowed enough moisture to accumulate, which would freeze when cold and seize/not return to original position after being actuated. He's forced air and some oil into it which should good enough until the replacement (new $73) cable arrives on Tuesday.
