![]() | Home > Technical (L322) > Roof rail removal |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 427 ![]() ![]() ![]() |
When I fitted mine, the only choice was to remove the flaps - literally had to break them off. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
personally I would keep them on. they look good on and you never know when you may need to use them. Also, with the rails, you can have the option of 3 cross bars to spread the land. you can only have 2 without and they are not slidable along the roof.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
The black ones on yours are quite elegant. The paint is peeling on the black parts, they are a bit shabby, and as I say I can’t see ever needing them.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
You have to buy the complete strip with the flaps in the colour of your vehicle - from memory they are quite expensive I looked at putting rails on mine years ago and went for whisbars as I could leave the flaps on and put roof rack on when I needed them |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
you could spray them black so they dont look so tacky... ... - .- -.
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 188 ![]() ![]() ![]() |
I bought some covers that slot over the holes ( sprayed them as they where black ) I can only find them know from USA but mine came from uk
They look like a good option, do they clip in place? |
They just drop in place |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Few on eBay...
Excellent, many thanks👍 |
Kevin if you do change, don't throw your away. I may be interested for my other Rangie. |
