![]() | Home > Technical (L322) > Heated Front Windshield only defrosting Driver Side |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I think the windscreen is split in two halves and there is a connector in each corner for the windscreen elements and the wiper strip down the bottom. If only half is working my guess is that one of the connectors may have worked loose.
karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105 ![]() ![]() ![]() |
Hello
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
The connections are under the "A" pillar trims, prise out the ""Airbag" emblem and there is one torx bolt, then pull the trim off towards the centre of the windscreen...
many thank's
Yes, hopefully if you have had it apart recently you will be able to sort it...
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
Bump |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Mine has been like that for years just use the FBH to defrost the whole car |
