![]() | Home > Technical (L322) > Second Compressor Install/Mod |
The Plan:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
why not just replace your pump with a newer one..the up/down speed is pretty quick on mine.. |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
I agree, just replace
I don't need to replace my one, I just want a secondary one. Much like the battery, no need, but want to see what is possible.
where will you fit it?, and how will you connect it up to the ecu, to ensure they work together |
I have LPG, so plenty of space in the spare wheel well... When mounted on the rubber mounts the pump is fairly silent.
wouldn't it be great if you could use the two compressors to make the range bounce like those american custom cars.. |
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 ![]() ![]() ![]() |
I have an image of the Mexican low riders in my head if you get the wiring wrong............please video! |
dan's not amused.... |
Someone's gotta come up with these daft ideas! |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
No 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I'm liking this idea. I've thought about this but never implemented. You can pic up some very cheap twin stage tyre compressors at a fraction of the cost of a new EAS pump. What pressure does the pump need to deliver? Dan might be worth sending Preston air an email as they are currently working on a compressor upgrade. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
The P38 pump was rated to 150psi IIRC. The L322 is a similar size / bladder setup. I dont imagine its going to be too much different from that.
