![]() | Home > Technical (L322) > Rear window rolling down by itself - Fixed! |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626
My rear right window doesn't want to stay shut and keeps rolling down by itself.
Update:
Regarding the failed switch, I tend to believe it's the terminals inside it that have made contact with ground due to corrosion.
| Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 113
fingers crossed you've cured it |
Oh the joys of JLR products ownership |
| MarkMurphy Member Since: 30 Oct 2022 Location: Cambridgeshire Posts: 16
I would also look at the anti trap wires. |
I thought about the anti trap strips but the clicking only occurs when the child safe is disabled. Windows roll up and down normally after the switch replacement. |
So, my rear left window switch finally also failed for good.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Excellent job. Saved some money there and you know your fix should be good.
Thanks, yes it actually took me two attempts to get the cleaning just right. It takes some persistence with the eraser at the bottom part of the contacts board. But if I can do this, anyone can |
| Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 308
Good job, thanks for the write up ! TDV8 4.4 2012 |
glad your sorted mate, nice to see these things are repairable given a bit of thought and time rather than just throwing money at issues |
