![]() | Home > Technical (L322) > FBH |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
Found this list of fuses / relays for 2002 to 2012 models hope this helps.
Just dug out my handbook for my 2006 Td6, in the book it has fuse No 59 (20 amps ) situated in the passenger compartment fuse box, named as 'Auxiliary heater ( diesel models only) independent heater' and in the rear load space fuse box it quotes fuse No15 (25 amps ) simply quoted as for 'Fuel pump' |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
The Webasto fuel pump is supplied directly from the FBH so there is no separate fuse. If the fuel pump is not operating, check there is a pulsed output from the FBH, if OK, then you need to access the pump to check the wiring there. Sometimes the pump can sieze due to lack of movement, a good few taps on it can free it off, once you've got to it. |
| All times are GMT |
