Home > Maintenance & Mods (L405) > Rear number plate size
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
On my previous L322’s the rear plate was larger than the front but on my L405 it is the same size and doesn’t look ‘right’! Can anyone tell me what the correct dimensions are for the rear plates so that I can order a replacement please?
Post #651471 22nd Dec 2022 7:25pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I have the larger one on the rear which is a private plate.
Post #651472 22nd Dec 2022 7:38pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I’ve had the same plates on all my cars since 2006, so 2 RR Sports, a Freelander 2, L322 FFRR and the current L405. The back one is bigger. I’d need to measure them for size though.
Post #651473 22nd Dec 2022 7:41pm
TJH1985
I got one from a dealer, duckworths actually the site sponsor it was cheaper than Halfords and the correct larger size Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #651474 22nd Dec 2022 7:41pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
When I swapped mine out I went a 20.5 X 5.5 (520mm x 140mm) on the rear which is 1.1" taller than the front plate, this was the same size as the dealer plate supplied originally. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #651477 22nd Dec 2022 8:12pm
Phoenix
The L322 ones were 'Oversize Plate 533 x 152mm' at the dealer group I worked for.
Post #651488 22nd Dec 2022 10:07pm
Gremlin500
@nickt68,
My rear plate is larger, trapezoidal with rounded corners, rather than just a plain rectangle, fitted by local Syntner LR Dealer,
so must be a proper JLR part. Looks really nice on the car, fills out the rear numberplate area well. I’d try to get this one if you can. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #651499 23rd Dec 2022 9:54am
nickt68
Thanks everyone, much appreciated
Post #651527 23rd Dec 2022 12:02pm
knwatkins
Same dimensions on the L405 Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #651537 23rd Dec 2022 12:45pm
knwatkins
Gremlin500 wrote:
@nickt68,
Have you got a pic Gremlin? All L405s come with rectangular, but oversized rear plates. Trapeziod rear plates are for the old L320 Sport due to the shape of the recess. Kev
Post #651538 23rd Dec 2022 12:54pm
Gremlin500
Sorry but I’m on holiday now for a few weeks, but I’ll post a pic asap.
The L405 does have two crease lines in the rear panel which flare out towards the top, so the rouded-off trapedoidal shape does look much better than straightforward rectangle. IMHO it looks more upmarket and OEM.
There must be a pic on the t’interweb in the meantime? V6 Vogue - “Less is More” - less to go wrong!
Post #651544 23rd Dec 2022 3:08pm
knwatkins
Unfortunately not, all L405 plates on the web are rectangular as this is factory standard.
The actual recess (the flat bit, where the plate mounts) on the L405 is rectangular, hence a rectangular plate...
On the old L320 Sport, the recess is trapezoidal, hence the trapezoidal plate...
Personally, I prefer a rectangular plate, even on the L320.
I'm intrigued to see how yours looks on the L405 though. Kev
Post #651547 23rd Dec 2022 3:30pm
do you really want your pride and joy to look like a back of a MG75, Laughing
Post #651549 23rd Dec 2022 3:37pm
knwatkins
Rolling with laughter Bow down Kev
Post #651550 23rd Dec 2022 3:42pm
I had to have a rectangular rear plate because I couldn't spell trapezoidal.... Pete
Post #651569 23rd Dec 2022 7:28pm
