![]() | Home > Technical (L405) > Auxilary Heater FFBH Fuel Pump info and pics |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Glad it's sorted for you, do you have the full beta programme from Gap for the IID, loads of extras options not on the standard programme..... |
fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47 ![]() ![]() ![]() |
I must admit I'm unsure about the iid tool, how do I get the beta version?
You were lucky neither pairs of connections had corroded! |
Yeah, i gave them a good squirt of contact cleaner before fitting, the fact it worked i left as was, its not to big a job to get to them now i have done it once, less than 3 minutes if you are using a battery wrench on the socket head bolts. |
Updated reader tool and app , its been ages since i last plugged it in on this car ( be a year ago,) more stuff availabe now its updated , cheers SDV8 2015 |
Sent an email to Pat at gapteam@gap-diagnostic.com ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Yes i will, just updated and checked still no facility to prime or run the FFBH as there was with the shop next door's Autel, bit bad really as its a thing that needs to be done, hardly " dealer Level" |
You are just updating what's already there, if you get the beta version from Gap it has many, many more things you can do, most of them have not been fully checked by Gap, hence they don't let you have it unless you ask for it... |
marshallc Member Since: 16 Nov 2022 Location: Chicago Posts: 2 ![]() ![]() ![]() |
Do you have any pics of the fuel line routing under the vehicle/under the sill? I have a 2016 US spec tdv6, it has a heater but no fuel line to it. I am going to pull the seat to look for wiring/aux pump but was curious as to routing. |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
Interesting as i had a similar experience. I purchased my 2015 AB from a MD. After a couple of months it was clear the FBH did not activate though the timed heating options were available to set on the main display. I purchased an IID tool which showed an open circuit on the fuel pump for the FBH.
