Home > Maintenance & Mods (L322) > SEAT CUSHION VALANCE - fixing?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
this is the 'trim' below the seat base that houses seat controls etc - has the 'silver' trim piece
from Britcar - HJR500021NUG
anyone fitted one?
thanks in anticipation
Post #65173 21st May 2011 11:48am
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
I also need to know how to do this Surprised
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #65174 21st May 2011 11:55am
dan_uk_1984
It's a bit of a "mare" to do, but just fiddly. Move the seat all the way forwards and up before you disconnect the multiplug otherwise you'll never get it off.
Post #65175 21st May 2011 11:57am
Ask member daveo think he got his seat re-done …..
http://www.fullfatrr.com/forum/topic4577.h...eat+fixing
Post #65176 21st May 2011 11:58am
nick h
dan_uk_1984 wrote:
It's a bit of a "mare" to do, but just fiddly. Move the seat all the way forward before you disconnect the multiplug otherwise you'll never get it off.
thanks Smile
does it just lever/pull off?
Post #65177 21st May 2011 12:06pm
dan_uk_1984
No, there are a few torx screws in there, you'll think you've got them all, but there will be a couple you'll miss. I missed the one at the back.
You'll figure it out.
Post #65178 21st May 2011 12:13pm
nick h wrote:
thanks Smile
Yes and no , once you have undone the screw at the back you need to carefully work your way around releasing all the clips and the seat control panel from the trim.
If you are replacing a cracked trim then I guess its not so bad to brake a few because like Dan said " it's a bit of a mare "
other wise some of the bigger clips at the bottom can be very stubborn . 2008 MY Supercharged
Post #65179 21st May 2011 12:15pm
nick h
axle wrote:
nick h wrote:
thanks Smile
thanks Thumbs Up
Post #65181 21st May 2011 12:32pm
M44K TS
The clips can be quite fragile as I found when I removed my old ones. If I remember rightly, refitting them, hook them on at the front first then clip them into place. Make sure the lumbar adjustment switch is clicked all the way in, it's a Censored when it pops out and you have to remove and refit a 2nd time. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #67521 7th Jun 2011 7:57pm
daveo
theres a screw at the back, you can see this fixing, then you want to unclip the trim at the front, i found if you push the trim into the seat at the front and pull out the part that curves around the front it will unclip, then there are 2 clips under the trim, you can see these if you get down and look under the seat, with your finger just pull down on them gently and it will release.
now theres 2 at the top and these are tricky and can end up broke but can be glued.just wiggle the trim and it will come off. Very Happy V8 facelift Range Rover Autobiography 22" wheels.
Post #67543 7th Jun 2011 8:47pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
At the risk of stating the obvious, and repeating what has already been said, if you are replacing the part, getting it off is not the issue - but make sure that the all the clips of the new part are perfectly aligned before committing, as if you engage the top clips and the rest is not aligned, releasing them without breaking them, is ......
Post #67563 7th Jun 2011 9:49pm
