Home > Technical (L322) > Jumping start from starter
mgrover
Tried to jump start from the starter motor, no dice. I mean the cars alarm kicks in but won't let me unlock.
I tried hooked up a car battery charger to start motor and negative cable on chasis and still same result. But now the charger says I have 14v instead. Is this some anti theft Censored ?
The manual method to get in doesn't work.
So am all outta ideas.
I guess for one am I tapping the right positive cable? i assume I am but what do I know. I removed there there was a cap and hooked up to there, when I check the battery is says 4-5v.
There are sparks from the chasis when I connect to it. So guessing that means it's the right one?
it's the 4.4 tdv8.
I do have 2 towing outlets at the back but not sure which is which to tap? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #651935 29th Dec 2022 2:58pm
mjdronfield
All I know is that I use the left one 🤣 so dug out a pic, it’s the white one my CTEK adapter uses.
No idea which pins though, sorry.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #651939 29th Dec 2022 3:48pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Re: Jumping start from starter
I reached this point today also. It does work but you have to be determined. Get the emergency key blade out of the fob. Fully insert it into the slot under the cover on the passenger door. Twist it toward the door whilst pulling top and bottom on the cover with the other hand. It will come off exposing the barrel lock. Now unlock with the key blade so that the other doors & bonnet can be opened from inside.
I was not able to jumpstart but I don’t understand why. I’m now on plan B which is to remove the battery and charge it out of the car. I’m not able to run the charger to the car as it’s on the opposite side of the road to my house but I have charged in-situ before and that has worked so it may be an option for you. TDV8 4.4 2012
Post #651953 29th Dec 2022 6:14pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Pin 4 +ve pin 3 -ve BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #651955 29th Dec 2022 6:20pm
mgrover
Am in.
Slow charging off starter motor did it. Still battery is Censored . Is there anyway I can make sure the bonnet doesn't lock when shut? Its actually a sport Sad
Post #651959 29th Dec 2022 6:34pm
mgrover
This mechanism is broken for me. Common issue it seems.
Am charging it in situ at the moment Its actually a sport Sad
Post #651960 29th Dec 2022 6:40pm
