![]() | Home > Technical (L322) > 2012 4.4 TDV8 - Air springs: how do they fail? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2684 ![]() ![]() |
The suspension fault is likely because the compressor didn't get the air reservoir up to pressure in the allowed time. As the front drops overnight the assumption can be made that air is leaking from an air-spring preventing the reservoir from filling soon enough.
It's not an ideal place to have this kind of issue. Air loss can also occur on the hoses, hose connectors and valves as well so don't assume it's the springs. The compressor will attempt to keep the pressure up but if it runs too long it will fail. 2012 TDV8 Vogue (L322) |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 123 ![]() ![]() ![]() |
Thanks for the replies.
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
They tend to fail right on the bend of material in the air bags at the bottom, where the expansion/contraction takes place. When my front left air spring went at 10 years old (just after I'd been using it in off-road height), I could see obvious cracks in it, and if I stood beside it and raised into off-road height, could see them widen into splits and hear the air gushing out!
'IF' the above is the case, then get some butyl repair tape from a hardware store, clean the airspring where it is leaking with brake cleaner or similar and apply a strip of the tape to the damper core, so that the rubber sleeve will roll over it when you lower the suspension, unless the leak is really bad, that will seal it until you can get home and replace the airspring. I know it works, I've done the above temporary repair and it got me back to UK from Libya many years ago.
So far it drives normal, the leak(s) can't be very big... yet.
You're more likely to find it in a hardware or plumbing store - they sell anything in Norway, I bought some brass wire for making snares from one, I have no idea what a plumber would use it for!
last week I went to a general electronics store in Lakselv to see if they had the Webasto remote CR11108 battery.
