![]() | Home > Technical (L322) > Information button on indicator stalk |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
My trip computer menu only provides selection of A, B or auto trip recording. |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Or a wiring issue...
| filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 82
Ok thanks bit advanced for me. But I have a thought that when it runs low on fuel and tells me how many miles left until empty I think it may go onto “ range” at that point. If I then put fuel in it it could remain on range rather than go back to “ trip A” worth a try anyway before a trip to the garage |
If all you want to do is have the range displayed, use the setup menu on the infotainment screen to deselect everything else. |
Ok thanks what’s it under on infotainment ? Can’t seem to see this on the menu ? |
Have a look at p95-96 in the owners handbook, if you don't have one you can find it online |
95-96 are climate control in my book. I have been though it today and can’t seem to see a section that says you can alter what you see on the dash from the infotainment to change it to range. |
https://www.fullfatrr.com/gallery/albums/u...%20OBC.pdf
2009 one of the first with the full digital dash etc |
Yep I don’t have any displays in the infotainment that look like this sorry |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Just to add to this, my 2008 3.6 has the facility. Appears on the touch screen for selection of information wanted. John
Ok thanks that’s good to know, do you know what it shows as on the menu on the infotainment or what I need to select ? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
a long press on the stalk end button will make this menu pop up... ... - .- -.
Not if the button circuit has a fault though... |
| All times are GMT |
