Home > Technical (L322) > Top coolant hose connection
mgrover
So as usual the top coolant hose decided to snap in that oh so magical location.
I remember seeing a metal version of the coolant junction if anyone has a link?
But the problem is someones been here before and has done a fix, problem is they've changed the connector type and i've got nowhere for this sucker to go
So can I just carefully remove this and hook up the existing connector? Or is there somewhere it should plugin? Or is that under the manifold? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #652088 30th Dec 2022 6:43pm
mgrover
i ended up cutting the quick fit pipe out and reusing the old pipe. it know it's not OEM but thinking about it seems to make more sense.
tomorrow is a coolant flush and drain and we'll see how she runs.
if anyone does know where i can get a metal coolant junction that'd be great, defo a future upgrade imo since these seem so brittle. Its actually a sport Sad
Post #652129 30th Dec 2022 11:42pm
blackpool
If you mean the (four way) connector at the other end of that thin hose in your photo I saw an aluminium connector on a forum in the states. I don't think they are available off the shelf. I concluded the person in question bought a large bore straight (or T) piece aluminium hose coupling (they can be googled - I think they are available in the UK) and then drilled and tapped (or welded) the two smaller side connectors.
The connector your image shows is on a breather hose and you usually disconnect it from the front of the plenum before removing the plenum.
Mine actually failed at the end you show in the image (sheared on the 90 degree bend) so I just bought the whole four way hose assembly. I believe they usually snap at the other end to the one you show - the four way end. Hence that guy made an aluminium version.
The original design is stupid.
Post #652135 31st Dec 2022 2:10am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i have got rid of that hose completely and fitted a rubber coolant hose, so i no longer have that speed fit connection!! 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #652147 31st Dec 2022 10:35am
mgrover
That's what previous mechanic did and now an inclined to stick with it Its actually a sport Sad
Post #652151 31st Dec 2022 11:06am
mgrover
am struggling to find how to bleed this sucker.
in the old bmws it was just open bleed screw. stick fan on high heat but low power and whack her in.
is it similar here? Its actually a sport Sad
Post #652163 31st Dec 2022 12:29pm
mgrover
Went with best judgement, whacked open bleed screw and started filling with the heater on full temp and power till it couldnt take anymore.
Ran car
Topped up as necessary to ensure plenty of fluid.
Once the level wouldn't drop anymore I close top of expansion tank. At this point it's overfilled.
Held revs at 1.5k for any extra air bubbles.
Checked heating was nice and hot. Currently I've got an inch over the cold fill line.
If that remains when cold ill suck out the extra coolant gg. Its actually a sport Sad
Post #652169 31st Dec 2022 1:42pm
blackpool
I used a vacuum filler but from memory the wiki workshop manual has bleeding instructions
Post #652178 31st Dec 2022 3:25pm
mgrover
Yeah was looking through it but couldnt find it Its actually a sport Sad
Post #652180 31st Dec 2022 3:40pm
mgrover
Went for a drive.
Got P1247-00
Guessing one of the pipes isnt connected properly
I didn't touch the map, I did remove the big pipe before it so probs it Its actually a sport Sad
Post #652202 31st Dec 2022 7:55pm
mgrover
It was the big hose with the intake temp sensor.
Did diffs, transfer box and power steering. That's all vital fluids done thankfully.
Just need to wait for a gearbox flush in couple of weeks Its actually a sport Sad
Post #652250 1st Jan 2023 5:11pm
MuddyTDi
Who are you planning on using for the gearbox flush?
Post #652297 2nd Jan 2023 7:37am
mgrover
The one, the only, Bodsy. Its actually a sport Sad
Post #652301 2nd Jan 2023 9:31am
