Home > Technical (L322) > Clicking driving me nuts
mgrover
Vid of it
https://youtube.com/shorts/19QDGHCUcEw?feature=share
It happens when I first get into the car on a morning. Clearly to do with the climate control system. Could be one of the blend motors? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #652285 1st Jan 2023 11:18pm
Can't hear any sound on the video...?? Pete
Post #652289 2nd Jan 2023 1:44am
greenrover
United States 2006 Range Rover HSE 4.4 V8 Giverny Green
I can't hear anything in the video but if I had to guess it's the fan inside the climate control module that blows air over the temperature sensor. You can try taking it apart, cleaning it, and putting grease on the spindle/bearing, but it won't make the noise go away completely. You could remove the fan entirely and live with slightly inaccurate cabin temps too I guess.
Post #652291 2nd Jan 2023 4:13am
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
I can hear it very clearly (with headphones)
It reminds of a similar noise I have coming from "somewhere underneath, slightly behind the middle of the car".
Not meaning to hog your thread, but does anyone have any idea what that could be? It's a rhythmic sound, similar to the one mgrover has.
Post #652292 2nd Jan 2023 6:11am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
FBH? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #652293 2nd Jan 2023 6:49am
mgrover
I haven't turned the car on yet or the fbh.
Just when unlock, open the door and step in. Its actually a sport Sad
Post #652294 2nd Jan 2023 7:01am
mgrover
Defo there, I'd turn it up Its actually a sport Sad
Post #652295 2nd Jan 2023 7:02am
mgrover
By climate control module you don't mean the blower fan that needs half the car removing to replace do you?
Or do you mean the panel itself. Its actually a sport Sad
Post #652296 2nd Jan 2023 7:03am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Nothing to bring to this discussion, but slightly amused when phrase "slightly inaccurate cabin temps" is used with L322. Coming from Saab´s, where you don´t ever need to touch the temp request unless you actually want to change what you are asking for, L322´s temp control is next to useless. Mine is basically cold or hot and there seems to be nothing wrong with the system, " it´s just that the Ford-system is not that good", answer you wouldn´t expect at this segment.
Post #652300 2nd Jan 2023 8:47am
Turned up fully, not muted and still no sound track at all from that short, which is weird as I can hear this one, from my early fatty no problem...
https://www.youtube.com/shorts/vn0cwOZrIQg
Is this the noise...??
If it is then it's the electrically controlled flap that takes air to the rear central vent, if you remove the side panel from the centre console you can find it behind there, I just unplugged it, it then sent air all the time to the rear but that's not really an issue...
Thumbs Up Pete
Post #652308 2nd Jan 2023 12:12pm
mgrover
Nah that's not the noise. It's way quieter than your vid. It's defo on my vid but just really quiet. Its actually a sport Sad
Post #652326 2nd Jan 2023 4:15pm
It could be one of the other flaps, take off both sides of the transmission tunnel, one torx 20 up high at the back and they pull off...
Then you maybe able to determine which one it is... if it is one...QQ Pete
Post #652334 2nd Jan 2023 5:01pm
greenrover
Just the panel itself. It's a tiny fan.
https://www.youtube.com/watch?v=RQTcT_vmc68 2006 HSE 4.4 gasser
Post #652399 3rd Jan 2023 6:34am
mgrover
I defo think it's an actuator.
I noticed when I ran the learn actuator limits on gap the noise occurs. Its actually a sport Sad
Post #653244 10th Jan 2023 10:40pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Having had the same on 2 different cars my money is on the blend motor/actuator behind the panel by your left knee. One screw to remove the panel and the motor just snaps in or out. 5 min job. One i took apart, cleaned, and lubed and it cured the issue. The 2nd did not respond to cleaning so I swapped it for a used one.
see this thread https://www.fullfatrr.com/forum/topic50136.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #653261 11th Jan 2023 1:02am
