![]() | Home > In Car Electronics (L322) > Smart key not found 2011 L322 |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
I had this on my L322 and D4, being a bit of a cheap skate I bought a cheap battery still got the same message and issue, bought a Duracell and it worked straight away. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
the forum consensus is that a duracell bought from a reputable source is the 'battery' for key fobs..
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
+1 for what Stan says, I always use Duracell batteries for both the Keys and the FBH Remote.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
Cheers guys I will certainly do just that , at the point of failure I installed a cheap Chinese battery out of a blister pack found in the cupboard as I had no other battery available.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Just to say that Varta (Mercedes use Varta) are also just as good as Duracell. You can get a 4 pack on Amazon pretty affordably. 2015 Range Rover Autobiography 4.4 SDV8 |
Well guys guess what it didn’t work 😩 fitted a brand new Duracell battery with a date code in 2025 and still the same
Maybe worth checking the antenna plugs haven't come loose. The owner's manual tells you where they are. 2015 Range Rover Autobiography 4.4 SDV8 |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
I’ve had this a few times, fitted new battery, still says the same thing.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201 ![]() ![]() ![]() |
remove any cheap phone chargers or any other electronic stuff you put last time. |
Well guys we have a result, disconnected the battery for about the 5 time over the past week and now it works , would of been nice to know what it was 🤔 1990 3.5 v8 defender
