Home > Technical (L322) > L322 gear selection problems.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
3.6 SDV8 Diesel 2008. 60k miles.
Gear selector in Park ok. Drops back into Reverse ok, you have drive. Into Neutral ok.
Selector won’t go back any further, even though the light beside the selector shows D. The dash board display shows neutral. But no drive. It sometimes shows Transmission fault. Occasionally, if you select the manual option, D comes up on the dash, and you have forward drive.
Any thoughts please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #652886 7th Jan 2023 5:04pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
SDV8 isn't an L322! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #652890 7th Jan 2023 5:36pm
Phoenix
Sounds like the age-old problem of the swivelling clamp on the selector arm not swivelling...
Get underneath with the selector in park, note the position of the arm on the 'box, remove the arm and the swivel clamp on the cable, clean it all up and rebuild with some decent grease - not copperslip!
Post #652893 7th Jan 2023 5:45pm
GrandadRob
Many thanks Phoenix, will check tomorrow.
JMC I stand corrected.
Not my car. 2013 SDV8 4.4 SE Luxor.
Post #652896 7th Jan 2023 5:57pm
GrandadRob
Phoenix, you were 100% correct. Simple fix, thanks very much. Thumbs Up 2013 SDV8 4.4 SE Luxor.
Post #653087 9th Jan 2023 5:51pm
Phoenix
No worries - glad it was a simple fix.
Post #653091 9th Jan 2023 6:05pm
