![]() | Home > Technical (L322) > Range Rover 2010 5.0L V8 Trolley Jacking Points |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
What are you trying to achieve, lift the body or lift the wheels?
bearhouse Member Since: 18 Jul 2020 Location: Hemel Hempstead Posts: 10 ![]() ![]() ![]() |
Many thanks for your reply. You couldn't send me a photo of where you mean could you? |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 628 ![]() ![]() ![]() |
I just used to leave the backdoor slightly ajar so that the steps stayed deployed and used the std jacking points. Simples. Doesn't work with soft close on the 405 obvs! Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
It's very obvious if you get under the vehicle. Right in the middle of the lower wishbone on the rear there's a recessed hole with a socking great big nut on it that's what I'm on about. Ed |
