It's near impossible to diagnose this kind of thing remotely I'm afraid. The fault codes are usually the symptom of an issue, not the root cause.
From the fault codes listed, there's probably a few things to check:
1. Faulty water in fuel sensor and/or change the fuel filter. Approx £60 for a new filter and salvage sensor
2. The remaining PCM faults seem to indicate a charged air leak. This could be a split intake manifold and/or boost hoses... all common failures on these engines. Approx £500 for a new manifold and hoses
3. MAF sensor on right side or MAP sensor. Approx £150 for new/salvage sensors
However, be very careful - I can't see how number 2 would cause the engine to stall, although entirely possible from a dirty fuel filter and potentially possible from a faulty MAF or MAP.
I would also do all the usual things - check for water contamination in the oil, take off a charge hose and look at the gunk in there and on the throttle body, put a sniff tester on the coolant etc.
If you're in Surrey, my advice would be to consult with the owner and ask if you can get a mechanic to look over it, limp it over to Glenrands (if the vehicle is in or near Surrey also) and spend a few hundred on a specialist opinion. It could save you thousands - there are many other possible causes including injectors, timing, crank, split block etc that can't be diagnosed online.
The other thing I'd advise - unless you're a home mechanic, walk away. There's usually a reason someone hasn't had a fault resolved, and that's because they know it's a big/expensive one. 2015 Range Rover Autobiography 4.4 SDV8
