Home > In Car Electronics (L405) > L405 Sat Nav repair
e600
United Kingdom 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Sat nav fault identified as gps antenna. The part number is LR 059750. JLR currently out of stock with no know date for supply. A bit of a long shot, has anyone got one spare which of course I would buy.
Tia
Post #653305 11th Jan 2023 7:47pm
Phoenix
If you're at all handy, you could mount any 5V coaxial GPS antenna in the existing housing - they're reasonably cheap enough to give it a try.
https://www.ebay.co.uk/sch/i.html?_nkw=gps..._PrefLoc=2
Post #653318 11th Jan 2023 9:54pm
Fifth Horseman
If you search on eBay for CPLA19C089CC (the engineering part number for LR059750) there are plenty to be found.
Sellers tend to quote this number which is printed on a label in the aerial rather than the stock number which is usually only found on the box the part comes in.
Be aware the list price new is about £65
Post #653337 12th Jan 2023 12:04am
e600
Many thanks, that’s helpful. I will wait and see what JLR come back with on delivery times and then make a decision on a secondhand unit.
Post #653347 12th Jan 2023 2:04am
e600
My satnav now working fine, was the aerial, about £65 from main dealer, easy fit under headlining. Couple of plugs and two nuts with washers and a spreader plate.
Post #655205 31st Jan 2023 12:34am
bit late to this thread but i had DAB problems where in certain areas my signal would drop...this happen always after rain and never when the weather was dry..
figured out it was water accumulating in the little channel around the roof antenna and leaking into the electronics..
solution was to put a thin bead of black mastic around the base of the antenna...problem solved ... ... - .- -.
Post #655220 31st Jan 2023 8:36am
e600
Yes, whilst the aerial base has two slimline gaskets I gave both of them a lick of sealant. Should stop any future issues.
Post #655357 1st Feb 2023 4:30pm
yelnats6969
Nigelhirst wrote:
Yes - every time I turn the engine on I have to resent the country to GBR, where it stays until I turn it off. (Apparently the sat nav manufacturer is based in Belgium).
The postcode icon is permanently greyed-out, irrespective of which country is set.
Anyway, the extended warranty company has agreed to pay for the fix, so we will never know....
Nigel
Did you ever find out what part was replaced or how they fixed it
Post #685657 15th Feb 2024 12:52am
