Home > Maintenance & Mods (L322) > What windscreen should I have
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi All,
developed a crack in the windscreen on Saturday and now need a replacement (has a 6 inch crack in it).
All covered on th einsurance and National Windscreen want to come out tomorrow to fit a replacement. When questioned they said they don't use an official LR one but one supplied by Pilkington. Apparently the same one that goes to LR (But who knows.?)
Should I be insisting on a LR replacement or doe s it not really matter?
Thanks all Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #65328 23rd May 2011 8:01am
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
i thought they were pilkington glass Question ONE LIFE LIVE IT
Post #65338 23rd May 2011 9:14am
dan_uk_1984
The LR ones are made by Pilkington.
You should ensure that they are sending you one for use with a rain sensor though! Oh and if you've got the blue/green banding at the top of the screen. Finally make sure it's heated.
Post #65344 23rd May 2011 10:17am
comports
Great - I asked for the one with the Light/Rain sensor and also heated screen anyway. Also told them the car has "Green" glass so hopefully it will be correct.
I just can't remember if mine has a green "sun strip" along the top. It probably has though.
I didn't tell them about that (as I couldn't remember). Should I call them back to confirm or is it likely to have it anyway as I told them it has green glass? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #65355 23rd May 2011 11:02am
dan_uk_1984
Might be wortj a quick call to check - but just depends what you want really.
Post #65394 23rd May 2011 2:52pm
