Home > Technical (L322) > What’s going on with these brake lights?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Just noticed my brake lights are faulty.
They come, but in a few LEDS in each one. Same LEDS on both sides. Fuse is fine?
Help!
Post #653462 13th Jan 2023 3:44pm
Phoenix
Check the metal contacts on the lampholder for corrosion, then work out where the moisture is getting in.
Your symptom is typical for low voltage due to high resistance.
Post #653482 13th Jan 2023 5:15pm
philip1972
Thank you!
I have fixed it, but i am an idiot. A proper idiot. Neutral Neutral Neutral Neutral
2 weeks ago I was trying to fix the rear view camera. It seems I re plugged the high mounted brake light into the camera plug...as soon as I plugged it into the correct plug all was well again.
I hand my head in shame.
Post #653484 13th Jan 2023 5:19pm
