Home > Technical (L322) > Screen washing not washing
Mike_A4
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Six days in and the first fault:
Tried to clear the windscreen this morning for the firat time using the washers. After a long pause, driver's side was a miserable little squirt that just about found the glass, nothing from the passenger side. It did this several times.
Topped up the reserviour back at home - it was almost full, so low fluid wasn't the issue.
Now nothing at all, but the pump is audibly running. Rear screenwash works a treat. As faults go it could be worse, but not being to clean the windscreen is really not good.
Where is the pump and what route does the tubing take? I'm guessing that the pipe is disconnected or damaged somewhere.
Post #653119 9th Jan 2023 9:01pm
lift the bonnet and you'll see the tubing . ... - .- -.
Post #653121 9th Jan 2023 9:17pm
garyRR
Forgive stating the obvious, but have you used a needle in the jets, in case they are clogged with dirt or the previous owner used tap water instead of screenwash, and could be limescaled up? 2015 Range Rover Autobiography 4.4 SDV8
Post #653125 9th Jan 2023 9:43pm
Mike_A4
Duly forgiven Gary, although it required a bit of compressed air to do the trick. Typically we thought of that after the airbox had been removed to access the reservior.
Now I can clearly see... that I need new wiper blades.
Post #653190 10th Jan 2023 3:51pm
Mike_A4
This actually gets much sillier.
They were working in the workshop. I know this, because Mr Mechanic managed to soak himself. So be it. Job done. Except…
I tried to use them last night. Back to Square One: pump running, no water. Mutter mutter mutter.
I’ve just found a gap in the rain in daylight and gone to try to separate the tubes on the underside of the bonnet and blow air down them again. Whilst I was tugging fruitlessly away at the t-pipe connector I spied the problem. As the bonnet closes, the tube and wiring loom curve nicely away past the battery and the tube is very precisely trapped by the closing bonnet seal. Judging by the dent in the seal and the flatness of the tube, this has been going on for some time.
FFS.
A spot of tube re-routing on Sunday I think. But for the moment I can put this on the Problem Solved list.
Post #653460 13th Jan 2023 3:34pm
DrRob
Laughing Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #653469 13th Jan 2023 4:01pm
Discotigger
There should be a plastic panel that clips in over the battery in the engine bay that has two clips to hold and route the washer pipes to stop them getting pinched by the bonnet. It sounds like either it's missing on your FF or has been broken.
This is the plastic panel, shown in this thread:
https://www.fullfatrr.com/forum/topic65619.html
Post #653487 13th Jan 2023 5:21pm
Mike_A4
There's a panel...? I might have to take a photograph.
Post #653490 13th Jan 2023 5:32pm
Discotigger
See the thread in my edit above.
Also here:
Post #653491 13th Jan 2023 5:33pm
Mike_A4
I am so missing one of those! Does it have a part number?
Post #653493 13th Jan 2023 5:36pm
Discotigger
It probably does, it's dark and raining here at the moment, but I'll have a look in the morning and get you the part number if it's on it. Thumbs Up
Post #653494 13th Jan 2023 5:39pm
Mike_A4
Top chap, thank you.
Post #653495 13th Jan 2023 5:40pm
Discotigger
Hi Mike_A4.
Part number for the plastic Battery Bracket is:
AH42 5162 AB
Hope this helps Thumbs Up
Post #653562 14th Jan 2023 2:23pm
Mike_A4
Brilliant, thank you. I'll get one on order this week... as soon as the alternator is sorted. Now the bonnet has been up and, more awkwardly, down several times this weekend, the need is obvious!
Post #653622 15th Jan 2023 1:22pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
I had the same problem and it seems I'm missing that plastic bracket too! Cam
2011 TDV8 Vogue in Stornoway Grey
Post #653824 17th Jan 2023 6:29pm
