![]() | Home > Maintenance & Mods (L405) > Drivers seat loose |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i'd run the seat forwards to its most extent and again fully back a couple of times..you never know.. ... - .- -.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442 ![]() ![]() |
Look in the WIKI at the WSM, could be frame fixings loose. There is a diagnostic routine in the seating section to help you identify the potential problem. 2018 SE SDV8 4.4 Byron Blue |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251 ![]() ![]() ![]() |
‘Wiki at the wsm ‘ sorry where? You mean the wiki here and the workshop manual? --
Tried this but the seat is still rocking at both extremes and after doing. -- On my third Full Fat RR |
wiki link is at the top of the page on the right, wsm= work shop manual.. ... - .- -.
it feels like a screw has come loose or a clip has broken or maybe even part of the seat subframe has broken. I can't see anything but when I accelerate the chair rocks back. The lefthand side seems firm but the right is loose. Looking at the WSM it looks like you can take the plastic moulding off reasonably easily and that might allow enough access to tighten something but I don't know what. Andrew -- On my third Full Fat RR |
Just to update, in case is useful for anyone else, I’m at the main dealer and they think is a broken seat frame - which is not covered by my extended warranty (one of the exclusions).
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Always the way |
Apparently, the seat frame itself is fine but there is a bar - like a long screw which goes between the left and right rail and that somehow has bent.
if it goes again i'd look at ebay, theres bound to be something on there.. ... - .- -.
sadly it has gone again |
